unity error
May 29th, 2007
I have error event monitoring setup on my Unity machine. Lately I've been receive four messages regularly, but I don't know how to fix them. Could someone point me in the right direction. The messages are
1."Event Type: Error
Event Source: CiscoUnity_AMISConv
Event Category: Network
Event ID: 130
Date: 5/29/2007
Time: 12:30:16 PM
User: N/A
Computer: RYLUNITY01
Description:
An incoming call transmitted the DTMF C tone, which signals the beginning of an AMIS call. However, Cisco Unity was not able to find the UAMIS_<Servername> mailbox, so the message could not be accepted. Recommended Action: If the system is not configured for AMIS and should not except AMIS calls, this message can be safely ignored. If the rogue AMIS calls continue, you can obtain caller ID and other information by enabling the micro traces Conv PhoneHandler 10 and MiuGeneral 14 in the Cisco Unity Diagnostic Tool, or you can work with your carrier to determine the source. If the system is configured for AMIS and should accept AMIS calls, make sure that you have created the UAMIS_<Servername> mailbox before sending and/or receiving any messages using AMIS Networking. Refer to your Networking in Cisco Unity Guide for more information on how to properly configure your Cisco Unity server to use AMIS Networking. Error code = 0x8000ffff 152"
2."Event Type: Error
Event Source: CiscoUnity_Miu
Event Category: Error
Event ID: 559
Date: 5/29/2007
Time: 9:55:45 AM
User: N/A
Description:
Cisco Unity's telephony component has encountered a serious error.
EXPLANATION:
A serious failure has occurred on port 4 while dropping a call. In some cases, further calls on this port will not be handled correctly.
TECHNICAL DETAILS:
Thread 0x000017A4 had a failure on port 4 in method CAvMiuLine::Drop()
DESCRIPTION: Drop() called lineDrop() 0 times with result E_MIU_TIMEOUT..
DETAILS:
HCALL: 0x000111EA
CallState: LINECALLSTATE_OFFERING.
CALLINFO:
CallerID: Unknown
CalledID: 2288
RedirectingID: 2288
Origin: Internal
Reason: FwdUncond
Trunk: 0.
CALL SEQUENCE:
[09:54:28:662 - 0x00001700] Drop() - S_OK
[09:54:28:803 - 0x0000175C] WavOpen(0x0829B8C0) - 0x0012E07A
[09:54:28:803 - 0x0000175C] WavGetLength(0x0012E07A) - 36260
[09:54:28:803 - 0x0000175C] WavSetLength(0x0012E07A | 36260) - 36260
[09:54:28:803 - 0x0000175C] Record(RecLength 42532) - E_MIU_TERM_DISCONNECT
[09:54:44:881 - 0x00001060] LINE_APPNEWCALL(0x000111EA)
[09:54:44:881 - 0x00001060] SetEvent(NewCall)
[09:54:44:881 - 0x00001060] SetEvent(CallInfoArrived)
[09:54:45:131 - 0x000017A4] Answer() entered
[09:54:45:131 - 0x000017A4] lineAnswer(0x000111EA) - 0x000113B6
[09:54:45:131 - 0x00001060] LINE_REPLY(0x000113B6 | 0x00000000)
[09:54:45:350 - 0x00001060] SetEvent(CallInfoArrived)
[09:55:15:131 - 0x000017A4] WaitFor(0x000113B6 | CONNECTED) - Timeout
[09:55:15:162 - 0x000017A4] Answer() - E_MIU_TIMEOUT
[09:55:15:162 - 0x000017A4] Drop() entered
[09:55:15:162 - 0x000017A4] Drop Iteration 1 Call State: LINECALLSTATE_OFFERING
[09:55:15:162 - 0x000017A4] Answer() entered
[09:55:15:225 - 0x000017A4] lineAnswer(0x000111EA) - 0x00010D84
[09:55:15:225 - 0x00001060] LINE_REPLY(0x00010D84 | 0x00000000)
[09:55:45:225 - 0x000017A4] WaitFor(0x00010D84 | CONNECTED) - Timeout
[09:55:45:225 - 0x000017A4] Answer() - E_MIU_TIMEOUT."
3."Event Type: Error
Event Source: CSAgent
Event Category: Kernel Rule
Event ID: 256
Date: 5/29/2007
Time: 6:15:01 AM
User: N/A
Description:
The process 'C:\WINNT\system32\mstask.exe' (as user VOICEMAIL\Administrator) tried to open the file 'C:\WINNT\system32\cmd.exe' and was denied."
4.Event Type: Error
Event Source: MSExchangeAL
Event Category: Address List Synchronization
Event ID: 8331
Date: 5/28/2007
Time: 2:16:06 AM
User: N/A
Description:
The service threw an unexpected exception which was caught at m:\dsa\src\lra\abv_dg\lservagent.cpp(4664)
I am running unity version 4.0(5) and exchange 2000,i think
