Kerberos Contraint Delegation and Cisco SSL VPN
May 29th, 2007
Guys, I am evaluating the Cisco SSL VPN solution against another vendor.
I see that the Cisco SSL VPN solution does not support Kerberos Constraint Delegation. Can someone shed some light on this and tell me what the heck I will be losing if I use an SSL VPN solution which does not support Kerberos Constraint Delegation? Also, please tell me in which example or scenario Microsoft/Active Directory applications should suffer if such Kerberos Constraint Delegation is not supported.
Thanks!
smahbub Mon, 06/04/2007 - 08:55
  • Silver, 250 points or more
Your vpn connection simply won't come up
news2010a Mon, 06/04/2007 - 13:01
Not sure if I understand your answer.
I talked to a Cisco SE on this and he told me that Cisco SSL VPN does not support Kerberos Constraint Delegation with protocol transition.
