Does each configured WLAN (SSID) generate a separate LWAPP Tunnel?
Answered Question
May 29th, 2007
Does each configured WLAN (SSID) generate a separate LWAPP tunnel and a separate Beacon?
Correct Answer by rseiler about 9 years 7 months ago
Well, a 'tunnel' is really just defined as traffic sent between 2 endpoints encapsulated in another protocol. Therefore, by definition, the AP only has a *single* 'tunnel' to the controller.
Obviously the LWAPP protocol has header information that clearly communicates the SSID and frame type (user, maint, keepalive, admin, config, etc.) between the controller and the AP.
Ethereal has a pretty good packet decode for LWAPP traffic and may be a good start if you want to dissect the protocol further...
Overall Rating: 4 (1 ratings)
Correct Answer
rseiler Tue, 05/29/2007 - 17:59
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
