Router Configuration HELP
May 29th, 2007
My router doesn't seem to be passing traffic. I have a static route set, but it's not working. I'm new to router configuration, can someone help?
scottmac Tue, 05/29/2007 - 14:59
  • Green, 3000 points or more
Post your (sanitized) config, the router model, and the version of IOS you're using.
It may also be useful to know who/what's in the other side and beyond.
Scott
hx2 Tue, 05/29/2007 - 15:12
Here is my configuration:
pe-coc-connect>
pe-coc-connect>
pe-coc-connect>show ver
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 25-Oct-05 17:10 by evmiller
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
pe-coc-connect uptime is 1 hour, 49 minutes
System image file is "flash:c1841-ipbase-mz.124-1c.bin"
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FTX1118Z01P
2 FastEthernet interfaces
1 Serial interface
WIC T1-DSU
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2142
pe-coc-connect>
pe-coc-connect>
pe-coc-connect#show run
Building configuration...
Current configuration : 925 bytes
version 12.4
hostname pe-coc-connect
boot-start-marker
boot-end-marker
enable secret xxx
enable password *****
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
snmp-timeout 180
ip subnet-zero
no ip routing
no ip cef
no ip dhcp use vrf connected
interface FastEthernet0/0
ip address 192.168.1.254 255.255.255.0
no ip route-cache
speed auto
half-duplex
no mop enabled
interface FastEthernet0/1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 10.111.248.14 255.255.255.248
encapsulation ppp
ip classless
ip route 0.0.0.0 0.0.0.0 10.111.248.9
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password *****
login
end
pe-coc-connect#
msubtain Tue, 05/29/2007 - 15:41
The reason is
NO IP ROUTING
also there are no NAT statements present for 192.168.1.0/24 Network.
Muhammad
paolo bevilacqua Tue, 05/29/2007 - 15:56
  • Hall of Fame,
    Founding Member
It's hard for a router to route when is told "no ip routing" :)
HX2 -- This is a jokeful remark and wish you good luck, do not hesitate to ask further questions once you have made the necessary config adjusts.
minumathur Tue, 05/29/2007 - 16:51
  • Bronze, 100 points or more
Put ip routing in configuration ,i beliave after that everthing is working, let me know if you face any problem.
-Minuj
hx2 Tue, 05/29/2007 - 17:22
something like:
ip route 0.0.0.0 0.0.0.0 s0/0/0
is that what is missing....
msubtain Tue, 05/29/2007 - 17:26
As i indicated earlier, If you look at the config you have sent, it has a statement
NO IP ROUTING
which is preventing your route to route the traffic.
0.0.0.0 0.0.0.0 is the default route for all traffic which is already present.
smothuku Tue, 05/29/2007 - 21:03
  • Silver, 250 points or more
Hi ,
go to config mode and issue the following command .
(config)#ip routing.
check whether the traffice is flowing or not after enabling ip routing.
Satish
hx2 Wed, 05/30/2007 - 08:47
Thanks....
That worked...
