DB Write with SQL
May 29th, 2007
Hi all,
I have problem with DB Write in CRA Editor
I can insert data in table in SQL server with this command
after run script, i see 123 is appeared in table1
But when i create variable X (interger ) with value=123 and using command
i test and see 0 row is altered. And after run script, no thing appeared in table1
Thanks first
Please reply as soon as possible.
I will vote 5 * for you.
Overall Rating: 5 (2 ratings)
sferland Wed, 05/30/2007 - 05:32
I think your problem is because you're using "@" instead of "$". Here is an example from one of my script:
INSERT INTO StatMenu(SessionID,DateTime,Choice) VALUES ($lCurrentSessionID,$strCurrentDateTime,'M1000')
There are two variables (String) and one hard-coded value ('M1000').
Hope this help !
conkinkinconkinkin Wed, 05/30/2007 - 17:47
Thanks Steven,
But when i use "$" instead of "@":
INSERT INTO table1(Number) VALUES($x);
I see this error when test this SQL command by click Excute button ont tab "Test"
" Test SQL Execution
Remote Error:Java.lang.NullPointerException
Hope you can help me.
sferland Thu, 05/31/2007 - 06:46
It's probably because at the time you clicked the "Execute" button, the value of the "x" was null.
Anyway, I never use this button. Try with a real call or with reactive debugging. It should work just fine.
