Could not access downloads.ironport.com
May 29th, 2007
I could not access it from the box, could not ping and traceroute.
Failure downloading upgrade list. (Error performing upgrade: I/O error opening URL
'http://downloads.ironport.com/asyncos/upgrade/?serial=0014220F4D70-4BFHW...')
any problem with donwloads site?
Doc_ironport Wed, 05/30/2007 - 03:16
downloads.ironport.com is actually hosted on Akamai, so this one hostname can point to hundreds or more of different hosts around the world - it will automatically pick the one that will give you the best performance based on where the request comes from, as well as which Akamai hosts are available.
In general it should never allocate you a host that is currently unreachable, but of course it's always possible due to the nature of the Internet!
I'd suggest trying again, and if it still doesn't work you can try changing the hostname to downloads-static.ironport.com. This will force it to use the IronPort server located in the US, and whilst we generally don't recommend this (if nothing else, it won't be as fast) it's a good backup.
Failing that, raise a call with support who will be able to walk through the problem with you.
kisanak_ironport Wed, 05/30/2007 - 03:25
Yes, it's possible.
I'm about to replace it with downloads-static when the connection restore again after couple of minutes.
Maybe it is also good to put downloads-static.ironport.com on the updateconfig as a secondary host if the primary host unreachable like this, automatically :) Like LDAP configuration.
Thanks.
