05-29-2007 10:00 PM
I am having 1760 Internet Router with 2 Mb Lease Line. I want to restrict my Proxy Server's IP to allocate only 512 K of Bandwidth and rest I want to allocate to my Mail Server for Mailing.
Pls tell me the easiest procedure with configuration.
Thanks all in advance.
Anis
05-29-2007 11:14 PM
To rate limit bandwidth usage on a router interface, you can go with CAR (Committed Access Rate), please do check the following document, you can rate limit certain traffic using ACL:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080760d90.html
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
05-30-2007 12:17 AM
Dear Mohammed,
Thnx for ur reply. But my 1760 with "flash:c1700-y-mz.123-14.T3.bin" is not supporting "rate-limit " command on Interface. Pls help.
05-30-2007 12:53 AM
This is weired because according to Cisco Feature Navigator it is supported on your platform with your current code, please do check:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Let me check it on one of my routers and feed you back.
HTH,
Mohammed Mahmoud.
