ASA 5505 strange problem
May 29th, 2007
I have a strange problem with ASA5505.
Some times iam not able to ping the outside interface from Internet and the VPN tunnels goes down.
If i reboot the ASA box i will be able to ping the outside interface and the VPN tunnels comes up.
#sh ver
Cisco Adaptive Security Appliance Software Version 7.2(2)
Device Manager Version 5.2(1)
Compiled on Wed 22-Nov-06 14:16 by builders
System image file is "disk0:/asa722-k8.bin"
Config file at boot was "startup-config"
BAR-ASA5505-01 up 1 hour 24 mins
Hardware: ASA5505, 256 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash LHF00L47 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Boot microcode : CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Int: Internal-Data0/0 : address is 0019.0724.9ee3, irq 11
1: Ext: Ethernet0/0 : address is 0019.0724.9edb, irq 255
2: Ext: Ethernet0/1 : address is 0019.0724.9edc, irq 255
3: Ext: Ethernet0/2 : address is 0019.0724.9edd, irq 255
4: Ext: Ethernet0/3 : address is 0019.0724.9ede, irq 255
5: Ext: Ethernet0/4 : address is 0019.0724.9edf, irq 255
6: Ext: Ethernet0/5 : address is 0019.0724.9ee0, irq 255
7: Ext: Ethernet0/6 : address is 0019.0724.9ee1, irq 255
8: Ext: Ethernet0/7 : address is 0019.0724.9ee2, irq 255
9: Int: Internal-Data0/1 : address is 0000.0003.0002, irq 255
10: Int: Not used : irq 255
11: Int: Not used : irq 255
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 3, DMZ Restricted
Inside Hosts : Unlimited
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
VPN Peers : 10
WebVPN Peers : 2
Dual ISPs : Disabled
VLAN Trunk Ports : 0
This platform has a Base license.
Serial Number: xxxx
Running Activation Key: xxx
Configuration register is 0x1
Configuration has not been modified since last system restart.
Can somebody tell me what could be the reason?
I have attached the config file.
john.croson Thu, 05/31/2007 - 09:32
I am seeing similar issues with my 5510. I have 2 lan-to-lan tunnels and multiple users connected via ipsec.
Twice today, I've had to issue the following to drop my lan-to-lan to get it re-established:
clear crypto ipsec sa peer
It's getting a little annoying, but it looks like I may have to update my ASA from 7.0(6) and the DM.
Now I have a question: To go from 7.0 to 7.2, do I have to go to 7.1 first?
TIA!
ckuriyar74 Thu, 05/31/2007 - 21:50
No not required, you can directly upgrade from 7.0 to 7.2
HTH if it does.
Chandru
Daniel.M.Edwards Wed, 06/06/2007 - 17:50
I have no clue what HTH stands for but if you didn't already figure out you can go directly from 7.0 to 7.2.
NOTE: You will want to look at interim releases for 7.2. I believe 7.2(19) is the latest one. There are several security related vulns that have been fixed since 7.2
eugeneg Fri, 07/20/2007 - 22:54
You have probably solved the problem already, so I may be too late with this suggestion:
One of my customers had a similar issue which we were able to resolve by hard setting the ethernet interfaces to 100Mbps and half duplex. It seems the ASA does not always auto-negotiate correctly causing the links to become flakey.
Hope this helps (HTH).
raghavendra.pn Mon, 07/30/2007 - 01:06
HI
When the problem occures have you tryied to ping from inside to outside, for outer interface which router is connected
