Campus does not discover ATM link
Answered Question
May 30th, 2007
  • Gold, 750 points or more
Hi everybody,
I noticed that one important wan-link was not discovered by campus.
It's an ATM link between bob and zap. It's been running stable for a couple of years and I'm tolled not to touch it.
I think that ilmi might not be configured the way it should be causing the atmInterfaceMyNeighborIpAddress not to be filled, causing the OID's read by campus to contain:
snmpwalk.pl -c NetDoc bob-core22 1.3.6.1.2.1.37.1.2.1.11
1.3.6.1.2.1.37.1.2.1.11.3 = IpAddress: 0.0.0.0
I've tried to diagnose a bit but I don't recall to much ATM stuff anymore.
Can anyone help?
Michel
bob-core22#show atm ilmi-status atm 2/0
Interface : ATM2/0 Interface Type : Unknown
ILMI VCC : (0, 16) ILMI Keepalive : Disabled
ILMI State: Restarting
bob-core22#sh run
interface ATM2/0
description bob to zap DS3 45mbp/s zap-core22 Circuit ID#LD001234
no ip address
ip route-cache flow
load-interval 30
atm scrambling cell-payload
atm framing cbitplcp
no atm ilmi-keepalive
no clns route-cache
interface ATM2/0.45 point-to-point
description Clear Channel T3 - PVC numbers are not valid - reference only
mtu 1500
ip address 12.16.25.69 255.255.255.252
ip ospf network point-to-point
pvc 45/45
oam-pvc manage
protocol ip inarp
bob-core22#deb atm ilmi
Setting ILMI debug for all interfaces.
bob-core22#ter mon
bob-core22#
May 30 08:39:38.898 GMT+2: ILMI(ATM2/0): Sending ilmiColdStart trap
May 30 08:39:38.898 GMT+2: ILMI(ATM2/0): No ILMI VC found
May 30 08:39:38.898 GMT+2: ILMI: Encapsulation error on o/g ILMI Pdu <ilmi_send_pkt> (ATM2/0)
May 30 08:39:38.898 GMT+2: ILMI: Unable to Send Pdu out <ilmi_send_trap>
zap-core22#show atm ilmi-status atm 3/0
Interface : ATM3/0 Interface Type : Unknown
zap-core22#sh run
interface ATM3/0
description zap to bob DS3 45mbp/s - bob-core11 Circuit ID#LD001234
no ip address
ip route-cache flow
load-interval 30
no clns route-cache
end
interface ATM3/0.45 point-to-point
description Clear Channel T3 - PVC numbers are not valid - reference only circuit ID <to be encoded>
mtu 1500
ip address 12.16.25.70 255.255.255.252
pvc 45/45
oam-pvc manage
protocol ip inarp
end
zap-core22#deb atm ilmi
May 30 07:37:27.236 UTC: ILMI(ATM3/0): Sending ilmiColdStart trap
May 30 07:37:27.236 UTC: ILMI(ATM3/0): No ILMI VC found
May 30 07:37:27.236 UTC: ILMI: Encapsulation error on o/g ILMI Pdu <ilmi_send_pkt> (ATM3/0)
May 30 07:37:27.236 UTC: ILMI: Unable to Send Pdu out <ilmi_send_trap>
Correct Answer by Joe Clarke about 9 years 11 months ago
You need to explicitly enable it on ATM with "cdp enable."
Overall Rating: 5 (1 ratings)
miheg Wed, 05/30/2007 - 01:37
I guess that the source of the problem is that ILMI is simply not configured.
It should probably be more like this:
Does anyone see if the commands I added may disturb the existing ones?
Michel
interface ATM3/0
no ip address
ip route-cache flow
load-interval 30
pvc bob-core11 0/16 ilmi
no clns route-cache
end
mtu 1500
pvc 45/45
ilmi manage
oam-pvc manage
protocol ip inarp
Joe Clarke Wed, 05/30/2007 - 07:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Actually, for a non-LANE link, you might be better off with CDP over ATM (provided your device supports it). CDP over ATM is supported in 12.2T and higher.
miheg Wed, 05/30/2007 - 21:37
I certainly prefer CDP, but CDP is globally on, and not disabled on this interface.
If you have an idea why it is not working on the ATM interface I'd appreciate.
.May 31 07:38:47.110 GMT+2: CDP-PA: version 2 packet sent out on GigabitEthernet0/2
.May 31 07:38:50.630 GMT+2: CDP-PA: Packet received from Tina-SUP720-11 on interface GigabitEthernet0/2
.May 31 07:38:50.630 GMT+2: **Entry found in cache**
.May 31 07:39:10.570 GMT+2: CDP-PA: Packet received from bob-core11 on interface GigabitEthernet0/3
.May 31 07:39:10.570 GMT+2: **Entry found in cache**
.May 31 07:39:18.262 GMT+2: CDP-PA: version 2 packet sent out on GigabitEthernet0/3
.May 31 07:39:19.398 GMT+2: CDP-PA: Packet received from wilma-core11 on interface Serial1/0
.May 31 07:39:19.398 GMT+2: **Entry found in cache**
.May 31 07:39:19.842 GMT+2: CDP-PA: version 2 packet sent out on Serial1/0
.May 31 07:39:47.110 GMT+2: CDP-PA: version 2 packet sent out on GigabitEthernet0/2
bob-core22#sh cdp
Global CDP information:
Sending CDP packets every 60 seconds
Sending a holdtime value of 180 seconds
Sending CDPv2 advertisements is enabled
bob-core22#sh ver
IOS (tm) 7200 Software (C7200-JS-M), Version 12.3(19), RELEASE SOFTWARE (fc2)
I guess my ATM memories have become more then just a bit rusty. :-|
Cheers,
Michel
Correct Answer
Joe Clarke Wed, 05/30/2007 - 21:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
miheg Fri, 06/01/2007 - 08:09
So on ATM it's the opposite of what it is on the other interface types? Good to know this!! Thanks for mentioning this as I would not have guessed it.
Joe, if the TAC would answer the questions like you do I would never buy anything anywhere else then at Cisco's
Cheers,
Michel
Joe Clarke Fri, 06/01/2007 - 08:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
When this feature was implemented, development decided to make CDP disabled on ATM by default much like frame-relay multi-point interfaces. This was covered by CSCdt03339.
