Hudge Embryonic connection (with negative value in log)
May 30th, 2007
I have the :
%ASA-6-201010: Embryonic connection limit exceeded -1/64 for inbound packet from 10.8.5.1/2738 to 10.6.5.10/3128 on interface Outside
error message with connexions problems.
I check in error decoder and it seem that the -1 is the number of Embryonic connection. Is it a known bug or i misunderstand sonething?
Then i make a show local-host to show the connections and the result is:
local host: <10.6.5.10>,
TCP flow count/limit = 3/100
TCP embryonic count to host = 4294967293
TCP intercept watermark = 70
UDP flow count/limit = 0/unlimited
Conn:
TCP out 10.8.21.1:513 in 10.6.5.10:80 idle 0:19:23 bytes 88258 flags UIO
TCP out 10.8.21.120:1464 in 110.6.5.10:80 idle 0:53:06 bytes 1579253 flags UIOB
TCP out 10.8.1.20:4572 in 10.6.5.10:80 idle 0:00:02 bytes 673021 flags UIOB
Interface fail-over: 1 active, 2 maximum active, 0 denied
The "TCP embryonic count to host = 4294967293" is possible ?
jj
