Help on OSPF
May 30th, 2007
How can I configure OSPF hello interval to 5 seconds and the OSPF dead interval to 20 second??
How can I Configure the OSPF communication between routers to use authentication with MD5 encrption
mohammedmahmoud Wed, 05/30/2007 - 00:41
  • Green, 3000 points or more
For Hello and dead interval:
Router (config-if) # ip ospf hello-interval seconds
Specify the length of time between the hello packets that the Cisco IOS software sends on an OSPF interface.
Router (config-if) # ip ospf dead-interval seconds
Set the number of seconds that a device's hello packets must not have been seen before its neighbors declare the OSPF router down.
For authentication:
Router (config-if) # ip ospf authentication message-digest
Router (config-if) # ip ospf message-digest-key x md5 password
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080094069.shtml
HTH, please do rate all helpful replies,
Mohammed Mahmoud,
