T3 Connectivity for Cisco 3825 ISR
May 30th, 2007
Hi Sir,
My customer requires T3 connectivity for their Cisco 3825 ISR.
Is NM-1T3/E3 the only option? Its data sheet as follows:
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a008010fba2.html
Kindly advise if there's any issue I have to look out for.
Secondly, is CAB-E1-BNC the correct cable for the above NM?
Thank you.
B.Rgds,
Lim TS
Overall Rating: 2 (1 ratings)
paolo bevilacqua Wed, 05/30/2007 - 06:18
  • Hall of Fame,
    Founding Member
Yes the right module is NM-1T3/E3. Cabling is made with coaxial and BNC connectors that I suggest you have made locally.
khaderbasha Fri, 06/29/2007 - 20:49
Where do I find step-by-step config of NM1-T3/E3 module in low end Cisco routers such as 2600/2651XM. Any link to a short online training or good documentation is appreciated.
Thanks.
Khader
