dgoodridge Wed, 05/30/2007 - 01:57
Testking is a very sore subject to post about, it's shrouded in taboo because the creators violate the NDA in a big way.
IMHO using a Testking to pass an exam that you do not have the knowledge/experience to pass is wrong and is paramount to cheating.
However, I do see the merits in using the Testking to gauge your level readiness for the real exam IF you are confident in your abilities on the subject matter.
So if you fit into the bottom category then $70 buys you some piece of mind that you are indeed ready or gives you an indicator that more revision is necessary.
If you fit the first category then don't bother. Buy a few books or go on a course and revise the traditional way by learning the subject matter.
Hope that helps,
Doug
MARK HEUZENROEDER Mon, 07/02/2007 - 18:06
I am unhappy with testking company & product.
See my posting under Conversation "Study material for CCIE written and lab"
Regards, MH
