7941/61 SIP phones on 3th Party IP PBX
May 30th, 2007
For the 7940/60 there is a clear description of what you need and have to configure. For the 7941/61 it isn't. Can somone help on the right documentation??
Overall Rating: 4 (1 ratings)
paolo bevilacqua Wed, 05/30/2007 - 06:24
  • Hall of Fame,
    Founding Member
the configuration tags in the XML file are the same. The phones may behave differently depending on the FW version, but configuration is the same.
