WiSM module compatability with EAP-FAST
May 30th, 2007
We are planning to install WiSM module in Cisco 6509 switch used for wireless LAN controller.
As per the document in cisco Wism module can't suppport for EAP-FAST authentication.
Please confirm WiSM module can support for EAP-FAST are not??
For WiSM module is required additional ACS are WiSM module it self work as ACS server?
Please clarify anyone about this?
Overall Rating: 4 (2 ratings)
ankbhasi Sun, 06/03/2007 - 05:11
Hi Tim,
4.1 does support EAP-FAST on WISM. There are lot of new features released in 4.1 release and many of the customers have already started using the same.
No doubt it's not too long this image is relesed on CCO as compared to other releases but yes I believe this image is a definetely a quality release.
Hope it goes fine in your network if you are planning for the same.
*Pls rate all helpfull post
rangakishore Mon, 06/04/2007 - 21:30
Hi, ankbhasi
Thanks for your reply, I saw the doucment of Cisco 6500 series wireless service module Q&A.
Thanking you,
Ranga Kishore
Trending Topics - Security & Network
