loading Unity Express license
Answered Question
May 30th, 2007
hi all,
I want to load a new license file for unity express 3.2
I do not have a ftp server to upload the file to the unity express module.
is there any other way (tftp for example)?
i will apreciate any help
Correct Answer by Brandon Buffin about 9 years 9 months ago
If you have a Windows machine, install IIS and setup an FTP site. You could also setup FTP in IOS, TFTP to the router and then FTP to the CUE module. The first option would be less work.
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Wed, 05/30/2007 - 05:15
Hope this helps.
Brandon
Markus Schneider Wed, 05/30/2007 - 06:13
It does indeed have to be ftp. I like filezilla (easy to use, works great, just google it--it'll be the first hit).
