Getting a 1131AP to join a controller in a different Mobility Group...
May 30th, 2007
I have a situation where I have three WiSM's or 6 controllers. The last WiSM we installed I have configured with a different mobility group due to the rev. of code that is on the new one. The new one is at 4.0.217.0 and the old ones are at 3.2.171.6. Since the old controllers randomly reboot, I didn't want to put a new controller that would require an upgrade to the AP in the same group. Since I have over 350 AP's, this could take down most of my wireless network.
My question is how can I get an AP from the first mobility group to join a controller in the second mobility group? I am using DNS to get the AP's to the controllers, not DHCP option 43. Is there a way to do this?
Thanks in advance...
Overall Rating: 4 (1 ratings)
ankbhasi Wed, 05/30/2007 - 07:25
Hi Friend,
Every AP will be having an option of primary,secondary and teritary controller.
So click on the AP which you want to move to different controller on different mobility group and configure that controller system name into primary controller option in that AP and Apply the settings and then reset the AP.
This AP will go and join new controller.
Ankur
*Pls rate all helpfull post
mkluemper Tue, 08/07/2007 - 07:44
My experience is that Pri/Sec/Ter assignment does NOT work across different Mobility Groups. Has anyone else had success in assigning Pri/Sec/Ter controller sysnames in a different Mobility Group?
Thanks.
mjk
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
