Amit Singh Wed, 05/30/2007 - 06:14
  • Cisco Employee,
Try disabling and re-enabling the http service on the switch by using " no ip http server " command. this should reset the service on the switch. Check if that helps.
Please rate if it does.
-amit singh
lydia.walther Wed, 05/30/2007 - 07:09
we tried that and it didn't help. The process seems to hang. We get a timeout when we telnet to port 80 of the device. CNA shows a broken connection symbol as well. Is there any other way to stop and restart a process?
Amit Singh Wed, 05/30/2007 - 07:24
  • Cisco Employee,
Nope there is no other way to kill and individual process on 3750. You have to reboot it.
-amit singh
