Help with configuring routing on 3750 switches
May 30th, 2007
Currently I have the following configured on my router, what I'd like to do is put this on my 3750 switch, my question is what changes do I need to make to enable this to occur:
interface FastEthernet0/0
ip address 10.11.8.2 255.255.248.0
no ip redirects
ip route-cache same-interface
ip route-cache flow
no ip mroute-cache
speed 100
full-duplex
standby 1 timers 5 15
standby 1 preempt
standby 1 authentication xxxxxxx
standby 1 ip 10.11.8.1
interface FastEthernet0/1
ip address 10.29.2.2 255.255.255.0
no ip redirects
ip route-cache flow
speed 100
full-duplex
router ospf 1
router-id 10.11.8.1
log-adjacency-changes
redistribute connected subnets route-map PRIVONLY
redistribute static subnets
redistribute rip metric 120
network 10.11.8.0 0.0.7.255 area 0
network 10.17.2.0 0.0.0.255 area 0
network 10.28.2.0 0.0.0.255 area 0
default-information originate
router rip
version 2
redistribute ospf 1
network 0.0.0.0
default-metric 30
ip flow-export source FastEthernet0/0
ip flow-export version 5
ip flow-export destination 10.11.9.11 9996
ip classless
ip route 0.0.0.0 0.0.0.0 10.11.8.5 150
ip route 10.0.0.0 255.0.0.0 Null0 220
ip route 10.1.0.0 255.255.0.0 10.11.8.21
access-list 2 remark ***** Routes that will be propagated *****
access-list 2 permit 10.0.0.0 0.255.255.255
access-list 2 permit 192.168.0.0 0.0.255.255
access-list 119 permit ip host 10.2.4.5 192.168.16.0 0.0.0.255
access-list 120 permit icmp host 10.2.4.5 192.168.16.0 0.0.0.255
route-map PRIVONLY permit 10
match ip address 2
Thanks in advance
Dan
Considering that the 3750 runs IOS this config will work most probably. However check whether the IOS in 3750 is able to run ospf for instance because as far as I know the routing protocols require enhanced image.
Anyway the port numbering will be different and if you want to configure the port for L3 then you have to issue the no switchport command and ip routing in global config mode to enable the routing itself.
Hope it helps,
Krisztian
Amit Singh Wed, 05/30/2007 - 06:42
  • Cisco Employee,
Dan,
Please paste the show version from your switch.
-amit singh
mheick Thu, 04/03/2008 - 07:25
Couple of things.
Netflow is not supported on the 3750 platform so you can go ahead and remove that config.
Turn on routing using the "ip routing" global config command.
Configure ports as Layer three interfaces by using the "no switchport" interface command.
mheick Thu, 04/03/2008 - 07:26
Couple of things.
