1- NIC to Router and 1- Company Lan?
May 30th, 2007
I know this might not be the smartest question ever but can I have 1 nic plugged into a router im tftp-ing to and 1 plugged into the company network at the same time? I am configing a ton of routers and want to be able to DL software at the same time from Cisco.
Thanks ahead.
b.speltz Tue, 06/05/2007 - 16:47
  • Bronze, 100 points or more
Yes, You can alwys do that with two nic cards
HoustonG33K Wed, 06/06/2007 - 11:05
Thats what I do now. The problem is that if Im programming a router with Con cable and a Xover cable for TFTP while I want to check something on Cisco.com using the other nic it never finds a web site because the computer doesnt know where to route the traffic.
I think the next step is a small switch.(trying not to do that)
david.bradley Thu, 06/07/2007 - 00:55
Depending on the type of workstation you are using you should be able to control the routing, just make you standard NIC connection the default gateway.
