Modem passthrough using mgcp.
May 30th, 2007
I have had a strange problem when using modems/faxes from a VG 224 through 3825 E1 via callmanager 4.1(3)
When the call was placed you would get 2 seconds of silence after the remote modem /fax had answered.Faxes could deal with this but modem got very confused.
I tracked it down to the command on the VG224 ,mgcp modem passthrough voip codec g711alaw.
If i removed this which means it ran as default ulaw , the gap of silence disappeared.Anyone seen anything similiar or can explain why to me.
s.jankowski Tue, 06/05/2007 - 16:49
The relevant configuration for fax passthrough on the VG200 is:
mgcp modem passthrough voip mode cisco
mgcp codec g729r8 packetization-period 20
thisisshanky Tue, 06/05/2007 - 17:15
At the same time, along with the above commands, You will need to disable Cisco fax relay (turned on by default) and also T38 fax relay.
no ccm-manager fax protocol cisco
mgcp t38 fax inhibit.
PS: please remember to rate posts!
