CSS Multiple VIP addresses pointing to same services.
Answered Question
May 30th, 2007
Is it possible to have two VIP addresses pointing to the same services? I have two public IP address that need to be pointed to the same two web servers internally. Would the config look like such...
owner web
content ssl-rule
protocol tcp
port 443
vip address xxx.xxx.xxx.201
vip address xxx.xxx.xxx.202
add service A
add service B
active
content web-rule
protocol tcp
port 80
add service A
add service B
active
Or would the configurations look like this?
owner web
content ssl-rule
protocol tcp
port 443
add service A
add service B
active
content web-rule
protocol tcp
port 80
add service A
add service B
active
owner web2
content ssl-rule2
protocol tcp
port 443
add service A
add service B
active
content web-rule2
protocol tcp
port 80
add service A
add service B
active
Thanks for the help?
Correct Answer by Gilles Dufour about 9 years 10 months ago
the 2nd option is the correct one.
You can only have 1 vip per content rule.
You can indeed reuse a service in as many content rules as you want.
Gilles.
Overall Rating: 5 (2 ratings)
Correct Answer
Gilles Dufour Wed, 05/30/2007 - 06:54
  • Cisco Employee,
Gilles.
sr2623235 Mon, 10/20/2008 - 21:46
Hi Gilles,
can i use the above configuration for two different web service..for example
circuit VLAN1
description "OUTSIDE"
ip address 192.168.206.30 255.255.255.0
ip virtual-router 1 priority 101 preempt
ip redundant-interface 1 192.168.206.32
ip redundant-vip 1 192.168.206.33
ip redundant-vip 2 192.168.206.34
circuit VLAN2
description "WEB SERVERS"
ip address 192.168.208.4 255.255.255.0
ip redundant-interface 1 192.168.208.6
service WEB1
ip address 192.168.208.10
string WEB1
keepalive port 9999
keepalive type tcp
keepalive tcp-close fin
keepalive frequency 60
active
service WEB11
ip address 192.168.208.11
string WEB11
keepalive port 9999
keepalive type tcp
active
service WEB2
ip add 192.168.208.15
keepalive port 80
keepalive type tcp
active
owner ABC
content ABC
vip address 192.168.206.33
protocol tcp
port 9999
add service WEB1
primarySorryServer WEB11
active
owner XYZ
content XYZ
vip 192.168.206.34
protocol tcp
port 80
add service WEB2
active
here both the services are entilrely different url, one is abc.com and other is xyz.com
is this correct..if not please correct me..
