Answered Question
May 30th, 2007
I'm not sure if I need to include GBICs into the configuration of the WS-C2950G-24-EI-DC, because in the description it is stated that 24 10/100 ports and two fixed 1000BASE-X uplink ports are included (, but in the Online Configurator it is stated Warning - Please order GBICs separately.
Are the GBICs included or not and how to include the GBICs in that bundle, because there is no option to select anything?
Correct Answer by Amit Singh about 9 years 4 months ago
You have to order the GBICS seprately. These dont come with the switches.
Please find the link below for the GBIC tranceivers that you can use with the switch.
Order the part number that suits your requirement.
HTH,Please rate if it does.
-amit singh
Overall Rating: 5 (1 ratings)
