dial in to cisco router 3845
May 30th, 2007
Hi everybody.
I have router 3845 and nm 16 a/s this piece of my config. Lcp has timeout like this Timeout: State REQsent what here wrong I did
aaa new-model
aaa authentication login default group radius local none
aaa authentication login console none
aaa authentication login no_log local none
aaa authentication ppp default group radius local none
aaa authorization network default group radius local none
aaa accounting update periodic 10 jitter maximum 20
aaa accounting system default start-stop group radius
interface Group-Async0
physical-layer async
ip unnumbered GigabitEthernet0/0.10
encapsulation ppp
no ip mroute-cache
async mode dedicated
peer default ip address pool dialin
ppp authentication ms-chap-v2 ms-chap chap pap
group-range 194 209
line 194 209
modem Dialin
modem autoconfigure discovery
autocommand ppp
transport input all
autoselect during-login
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
this is debug:
*May 30 20:54:31.463 GMT: %LINK-3-UPDOWN: Interface Serial3/0, changed state to up
*May 30 20:54:31.463 GMT: AAA/BIND(00000025): Bind i/f Serial3/0
*May 30 20:54:31.463 GMT: Se3/0 PPP: Using modem call direction
*May 30 20:54:31.463 GMT: Se3/0 PPP: Treating connection as a callin
*May 30 20:54:31.463 GMT: Se3/0 PPP: Session handle[60000048] Session id[28]
*May 30 20:54:31.463 GMT: Se3/0 PPP: Phase is ESTABLISHING, Passive Open
*May 30 20:54:31.463 GMT: Se3/0 LCP: State is Listen
*May 30 20:54:33.467 GMT: Se3/0 LCP: Timeout: State Listen
*May 30 20:54:33.467 GMT: Se3/0 PPP: Authorization required
*May 30 20:54:33.467 GMT: Se3/0 AAA/AUTHOR/LCP: Authorization succeeds trivially
*May 30 20:54:33.467 GMT: Se3/0 LCP: O CONFREQ [Listen] id 114 len 20
*May 30 20:54:33.467 GMT: Se3/0 LCP: ACCM 0x000A0000 (0x0206000A0000)
*May 30 20:54:33.467 GMT: Se3/0 LCP: MagicNumber 0x1B23E722 (0x05061B23E722)
*May 30 20:54:33.467 GMT: Se3/0 LCP: PFC (0x0702)
*May 30 20:54:33.467 GMT: Se3/0 LCP: ACFC (0x0802)
*May 30 20:54:35.483 GMT: Se3/0 LCP: Timeout: State REQsent
*May 30 20:54:35.483 GMT: Se3/0 LCP: O CONFREQ [REQsent] id 115 len 20
*May 30 20:54:35.483 GMT: Se3/0 LCP: ACCM 0x000A0000 (0x0206000A0000)
*May 30 20:54:35.483 GMT: Se3/0 LCP: MagicNumber 0x1B23E722 (0x05061B23E722)
*May 30 20:54:35.483 GMT: Se3/0 LCP: PFC (0x0702)
*May 30 20:54:35.483 GMT: Se3/0 LCP: ACFC (0x0802)
*May 30 20:54:53.627 GMT: Se3/0 LCP: Timeout: State REQsent
*May 30 20:54:53.627 GMT: Se3/0 LCP: State is Listen
*May 30 20:54:55.627 GMT: %LINK-5-CHANGED: Interface Serial3/0, changed state to reset
*May 30 20:54:55.627 GMT: Se3/0 PPP: Sending Acct Event[Down] id[25]
*May 30 20:54:55.627 GMT: Se3/0 LCP: State is Closed
*May 30 20:54:55.627 GMT: Se3/0 PPP: Phase is DOWN
*May 30 20:55:00.627 GMT: %LINK-3-UPDOWN: Interface Serial3/0, changed state to down
thanks before
Paolo Bevilacqua Wed, 05/30/2007 - 20:29
looks like the router is getting no input. Please verify that your modem port speed is set at 115200, and that you can have a terminal session when dialing with a terminal program. That will require "async mode interactive".
KAROLY KOHEGYI Thu, 10/04/2007 - 01:07
hi !
if you have still got the problem try the following.
interface group-async 0
no physical-layer async
