2801 Router w/ HWIC 9ESW Switch Module
May 30th, 2007
If I install the 9ESW Switch Module in a 2801 can it become another network?
For example, I want one network on Eth1, a second network on Eth2 and third network on the switch module. I want to route between the three networks.
Richard Burts Wed, 05/30/2007 - 08:17
With appropriate configuration of VLANs I would think it was quite possible. I have not tried to do this on that platform so I can not speak from experience. But I would think it was quite possible.
Amit Singh Wed, 05/30/2007 - 08:17
Yes, you can do that. You have to create L3 SVI's on the router and then assign the respective port to each vlan. You cannot create each interface as a Layer3 interface by giving it an IP address directly.
HTH,Please rate if it does.
-amit singh
