telnet on 831 router
May 30th, 2007
hi,
1)i configure eth0 with 10.5.10.1/24
2)i configure eth1 with 212.217.93.195/28
i can ping eth0 and eth1.
if i do "telnet 212.217.93.195" it 's work fine
but with "telnet 10.5.10.1" that's not work.
i don't know if it is normal or no.
Amit Singh Wed, 05/30/2007 - 08:36
  • Cisco Employee,
Please paste the router config.
-amit singh
yoyo_the_king Wed, 05/30/2007 - 09:18
this is my config:
Router#sh run
Building configuration...
Current configuration : 2497 bytes
version 12.4
no service pad
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
interface Loopback0
ip address *.*.*.* 255.255.255.0
interface Tunnel10
ip address *.*.*.* 255.255.255.252
ip access-group acl2 in
ip ospf cost 100
ip ospf mtu-ignore;
keepalive 10 3
tunnel source Ethernet0
tunnel destination *.*.*.*
interface Ethernet0
interface Ethernet1
description Frontal LAN
ip address *.*.*.* 255.255.255.240
ip mtu 1400
ip virtual-reassembly
ip tcp adjust-mss 1350
duplex auto
interface Ethernet2
no ip address
shutdown
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
router ospf 1
router-id *.*.*.*
log-adjacency-changes
redistribute static subnets route-map DISTRIBUTE-MAP
network *.*.*.* 0.0.0.0 area 0
ip route 0.0.0.0 0.0.0.0 *.*.*.*
no ip http server
no ip http secure-server
ip access-list standard ROUTAGE_acl
permit *.*.*.* 0.0.0.63
ip access-list extended acl2
permit gre host *.*.*.* host *.*.*.*
permit ospf any any
permit ip *.*.*.* 0.0.255.255 any
permit icmp any any
deny ip any any log
permit ip *.*.*.* 0.0.0.255 *.*.*.* 0.0.0.255
ip access-list extended acl1
route-map ***** permit 10
match ip address *****
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password 7 **********
login
scheduler max-task-time 5000
end
Router#
MATTHIAS SCHAERER Wed, 06/27/2007 - 03:26
Pretty difficult to say what the cause is with all IP addresses removed out of the config and no indication of the source IP address of the system that issued the telnet.
As an easy test I'd remove the ip access-group from the tunnel interface to see if this is the cause of the problem. If so, the coding of the acl must be reworked.
If this does not solve the problem I guess that the issue is on the originating system that does not have a route to network 10.x.x.x.
Mat
spremkumar Wed, 06/27/2007 - 03:37
  • Red, 2250 points or more
As Mat clearly pointed out you need to mention the source of the telnet request from which IP address you are trying to telnet.
That may help to identify the cause for the telnet issue...
regds
