PPPoA on Cisco 800 series
karim.bettich
Does anyone know what is the supported range of vpi/vci on a Cisco 827/837/877 atm interface configuration?
I could not configure vpi/vci 13/257 on a 1841 WIC-1DSL card because the max VCI supported value on this WIC is 255.
Does the 800 series present the same limitation?
the Cisco 800 Series (i took the 876W with Adv. Ent. Image for example) has no limitation.
I can configure VCI's from 1 to 1023.
Kind regards,
Christian
paolo bevilacqua
This is only a suggestion because I don't have the hardware to test this now, but can you try:
atm vc-per-vp 512
(or 1024, or any power of 2 that is possible accepted)
This helps, please rate post if it does!
on my 876W I can configure atm vc-per-vp 512 and 1024 but 1024 is the maximum.
Kind regards,
Christian
here's the output from the "atm vc-per-vp" command:
Lena(config-if)#atm vc-per-vp ?
32 VCs per VP
64
128
256
512
1024
