WAAS 4.0 in FE-511 Appliance
May 30th, 2007
Hello All,
We have some FE-511 appliances and we want to know
if it's possible to install WAAS 4.0 on them, with same results as if they were WAEs (say,512 or 612).
Are there any limitations to keep under consideration?
The actual version running on them is WAFS 3.0
Thanks in advance!
Pablo Lutenberg
Systems Engineer
SoftNet Logicalis
ARGENTINA
Overall Rating: 5 (1 ratings)
Zach Seils Wed, 05/30/2007 - 14:36
Pablo,
The FE-511 will support WAAS 4.0. The only limitations are the scalability of the device (i.e. it doesn't have the same scalability characteristics as a WAE-512/612).
Zach
mrrussell Wed, 06/06/2007 - 06:38
Following up, I presume the FE-511 runs the same images as the WAE-512?
Mick
