Voicemail ports disconnecting from Call Manager
May 30th, 2007
I been having issue with voicemail ports disconnecting from the call manager. I have 8 voicemail ports configured for one cluster and 8 for the other.
Cisco Unity-CM TSP device 15 (Cisco Unity port 12): Disconnected from Cisco Call Manager
If there are many of these messages in sequence from the same device 15, this port may not be functioning any more. Check to see that it is answering calls, and the server may need to be restarted to activate the port again.
The version of Unity is 4.2 Build 4.2(1)
Call Manager Version is 4.2(3)sr1
Tommer Catlin Wed, 05/30/2007 - 12:28
  • Green, 3000 points or more
What version TSP are you running? Log into Unity console and open up the UTIM and check the version. It could be old and need updating.
If not, maybe a simple reboot of Unity will clear it all out.
Tommer Catlin Wed, 05/30/2007 - 12:41
That is the latest and greatest. Is this a new integration or has it been running for a while?
marion.barnes@k... Wed, 05/30/2007 - 12:48
I have recently moved 8 of our voicemail ports to a new call manager cluster about two weeks ago. I only have issues with the voicemail port I moved to the new cluster.
Tommer Catlin Wed, 05/30/2007 - 12:50
yeah, thats a little odd. i would first start with rebooting Unity after hours and see what happens. This will reset the TSPs to each ccm and resynce everything backup. Worst case, delete the TSPs connected to that CCM and rebuild them from scratch. I have had issues in the past I could not figure out. But my last resort was to delete the integration and start over.
marion.barnes@k... Wed, 05/30/2007 - 12:56
Is there a document that can help with the intergation of voicemail ports. Maybe I'm missing something.
eschulz Wed, 05/30/2007 - 13:22
  • Cisco Employee,
Is the network topology between Unity and this second cluster significantly different than the first? Those disconnect errors could be a symptom of connectivity problems between Unity and CCM. Do you see the ports automatically reconnecting after some time?
Are you sure you even need dedicated ports for this second cluster? With your version of CCM, I would think you could set up Inter-Cluster Trunks that will support centralized voicemail (i.e. with the right dialplan, RDNIS and MWI and such can be passed across the ICT so that Unity only needs direct connection to one of the clusters).
-Eric
