WS-X6148A-GE-TX is not recognized by IOS
May 30th, 2007
I have been working on a 6509 with Sup engine SUP2-GE, version 12.1(8b)E11, that does not recognize the new 10/100/1000 48 port card. When listing modules it is unrecognized and power is off. Other error messages are: failed to read serial eeprom of line card in slot X and poser mgmt sprom failure for module X. The 10/100 module is read with no problem. Any suggestions?
Overall Rating: 4 (1 ratings)
jasonrandolph Wed, 05/30/2007 - 13:34
Module appears to only be supported by CatOS ver 8.4(1) or higher...not IOS
Basically hybrid CatOS/IOS or Native CatOS will be required for operation with the new card.
gmvburg23 Wed, 05/30/2007 - 14:10
The 10/100 48 port module is a WS-X6348 which works fine but the WS-S6148A-GE-TX is the one that does not work.
gmvburg23 Wed, 05/30/2007 - 14:00
According to this document ccmigration_09186a00800c8441.pdf
It is called "The Comparison of the Cisco Catalyst and Cisco IOS Operating Systems for the Cisco Catalyst 6500 Series Switch."
jasonrandolph Wed, 05/30/2007 - 14:08
I plugged your sup module and and the new linecard into the configurator, no compatible IOS version was returned.
Go here:
Selection 2, software advisor, specify hardware manually, and add in your line cards/modules/etc. It will then give you a software recommendation.
There are other pages that list no compatible IOS version for the card in the 6500 series as well if you search on the card's model # and look under minimum supporting software revision.
gmvburg23 Wed, 05/30/2007 - 14:20
That is not what I wanted to hear. I was hoping that I would not have to run in hybrid mode for the 10/100/1000. What about the WS-SUP2-MSC2 sup engine? Will this line card work in that environment along with the WS-X6348?
jasonrandolph Wed, 05/30/2007 - 14:40
The configurator may be out of date, so upgrading likely wouldn't hurt to try...
gmvburg23 Thu, 05/31/2007 - 05:28
There are a host of software updates to fit 12.2sx. One in particular that you are familiar with?
gmvburg23 Wed, 05/30/2007 - 14:58
I will try in the morning and let you guys know the outcome. Thanks!! I hope it works!!!
