PIX 6.3, more than one SNMP community?
May 30th, 2007
Can you add more than one community string to PIX firewall running 6.3?
If so,
Is it an ok practice to have a RW string on a PIX firewall in addition to the RO string?
Overall Rating: 5 (2 ratings)
acomiskey Wed, 05/30/2007 - 15:08
  • Green, 3000 points or more
You cannot do RW in pix.
wilson_1234_2 Wed, 05/30/2007 - 17:17
Thanks for the reply,
What do you do about Ciscoworks management with PIX?
Don't you need RW for some funtions?
Fernando_Meza Wed, 05/30/2007 - 17:32
  • Gold, 750 points or more
Hi ..
PIX firewalls allow limited SNMP support. Because SNMP was designed as a network
management protocol and not a security protocol, it can be used to exploit a device. For this
reason, the PIX Firewall allows only read-only access to remote connections. This enables
the manager to remotely connect to the device and monitor SNMP traps but does not allow
the manager to change any SNMP settings.
so answering your question Ciscoworks will not use SNMP to push down changes to the firewall.
I hope it helps .. please rate if it does !!!
