No ringtone back on CCM
Hello!
I have a strange problem with CCM 5.1 - no ringtone back when somebody call me from outsite. My phone is ring and if I'm answering - we can hear each other. Nobody hear ringtone back during NoAnswer. There is no problem one-way-voice. Call from me to outside don't have problem. There is no problem with inside call - ringtone back, call transfer work and so on... Connectivity h323-to-h323, ios c2800nm-advipservicesk9-mz.124-11.T.bin
Call from ISP terminated on 2811 and forward to CCM (basic h323-to-h323 connectivity)
[h323-isp]--[2811]--[ccm]
2811 config (main):
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
h225 timeout t302 30
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 192.168.44.5 255.255.255.252
ip nat outside
ip virtual-reassembly
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.44.5
interface FastEthernet0/1
ip address 192.168.1.251 255.255.255.0
ip nat inside
duplex auto
speed auto
dial-peer voice 1 voip
destination-pattern 101010
session target ipv4:192.168.1.250
dtmf-relay h245-alphanumeric
dial-peer voice 2 voip
destination-pattern 101011 progress_ind setup enable 3
progress_ind alert enable 8
192.168.1.250 - this is my CCM
I add progress_id to the second dial-peer but it isn't help me to solve problem.
Overall Rating: 5 (1 ratings)
Tommer Catlin Mon, 10/12/2009 - 19:54
Thanks Rob. That helped me today! progress tone 3 seemed to do the trick for me. Nortel ---h323---CUCM 6.14. Added in the dial peer and whamo.
Thanks!
