issue over cabling
crackcisco
we r having netgear wireless router and evrything is wireless except two laptops..the problem s with the cabling..following r the cabling specifications...cat 5e and 568B ...and coming to the problem
wat i read is wen we connect a pc to a router directly one has to opt for croossover but, wat i saw
here is completly different, inside the rj45 the color combi were different frm crossover and still its working fine..wat they were using is this
(wen hook is underneath and this is @ both the ends)
white orange,orange
white blue, green
white green,blue
white brown,brown....this is for one laptop
and for another latop
white brown , brown
white green , green
white blue , blue
white orange, orange , @ both ends and wen hook is underneath
can any1 tell me wats happening here
pavansuraj
Hi Srikanth,
The color combination of both cables you mentioned specify that of a straight through cable.
If you are connecting your laptop to a port which supports MDX(Media device Crossover), you can connect either by using straight through or crossover cable.
HTH, Please rate if it does
Pavan
thanx pavan, i don't knw abt this...but wen we go for strightover cable..we hav got some prescribed wa of wiring like
orange white,orange
green white,blue
blue white,green
brown white,brown)...but by looking @ the color combi in my previous post i was somewat
confused whether to follow which combi
thnx again
scottmac
Level 10
Level 10
Niether of the cable you've described are following the standard pinout scheme.
For 568a the color order (pin 1 on the left, hook down, cable end towards you)
1 - White-Green
2 - Green
3 - White-Orange
4 - Blue
5 - White-Blue
6 - Orange
7 - White-Brown
8 - Brown
For 568b:
1 - White-Orange
2 - Orange
3 - White-Green
4 - Blue
5 - White-Blue
6 - Green
7 - White-Brown
8 - Brown
Note that Ethernet / Fast Ethernet always use the orange and green pair. For GigE, all four pair are used in both directions (Tx/Rx) at the same time.
A standard Ethernet / fast Ethernet cable swaps pins 1&2, 3&6 (the orange and green pair) from one end to the other.
For GigE crossovers (needed for some older equipment without auto-sense) you also need to cross 4&5 (blue pair), 7&8 (brown pair).
Color order is critical for maximum performance, especially in Fast Ethernet / Full Duplex.
Good Luck
Scott
