Setting CoS value on QinQ (ME3400)
May 30th, 2007
I would like to set the QinQ tunnel CoS value. According to the docus:
http://cisco.com/en/US/products/ps6580/products_configuration_guide_chapter09186a008081c8ad.html#wp1008908
Last sentence before the paragraph.
"The priority field on the metro tag is set to the interface class of service (CoS) priority configured on the tunnel port. (The default is zero if none is configured.)"
Question:
how can I configure the interface default CoS value.
kind regards
VBala'zs
swaroop.potdar Thu, 05/31/2007 - 01:38
  • Blue, 1500 points or more
Yes, I gave you the option for 7600, sorry for that.
1) For the ME3400 you can configure a parent policy on the uplink trunk.
2) This parent policy will have one child policy per Vlan (External Vlan -SP).
3) When you reference the child policy you will set the COS value to the desired value.
Here is the configuration guide to configure Hierarchial Policy Maps.
http://www.cisco.com/en/US/products/ps6580/products_configuration_guide_chapter09186a0080666643.html#wp1588585
HTH-Cheers,
Swaroop
bvarga Mon, 06/04/2007 - 02:38
I have made some lab investigation. Nice try, but I have two problems:
1. "set" commands are not supported on output policy-maps (only for input maps)
http://www.cisco.com/en/US/products/ps6580/products_configuration_guide_chapter09186a0080666643.html#wp1445053
2. Because the QinQ tunnel, the interface towards the customer is an "access" interface, therefore match on CoS is not supported.
So it seems to be mission impossible with the 3400.
kind regards
VBala'zs
jrichesin Thu, 06/07/2007 - 16:13
There has got to be a way to do this. I am in the same boat so if anyone knows of a way to do this please post it.
Josh
swaroop.potdar Thu, 06/07/2007 - 21:33
VBala'zs, Josh I will try and simulate this when possible and would be glad to share the results.
If you can confirm did you try the input policy map with set cos on the ingress interface where you receive the customer traffic into the Dot1Q Tunnel port.
HTH-Cheers,
Swaroop
bvarga Wed, 06/13/2007 - 20:58
sorry I was away for a while. Yes I can confirm. Pls see below:
class-map match-any best-effort
match cos 0 1 2 3
class-map match-any premium
match cos 4 5 6 7
policy-map upstream-local-marking
class premium
set qos-group 1
class best-effort
set qos-group 0
interface "towards customer"
no shutdown
switchport access vlan 100
switchport mode dot1q-tunnel
mflex-me3400(config-if)#service-policy input upstream-local-marking
QM: 'match cos' and 'set' from-type 'cos' supported only with Trunk
interfaces
'match cos' supported only with IEEE 802.1Q/ISL interfaces
regards
Bala'zs
swaroop.potdar Thu, 06/14/2007 - 23:17
hmm...well can you try this one...
mflex-me3400(config)# table-map prec-to-cos
mflex-me3400(config-tablemap)# default 5
mflex-me3400(config-tablemap)# end
mflex-me3400(config)# policy-map setcos
mflex-me3400(config-pmap)# class class-default
mflex-me3400(config-pmap-c)# set prec 5 table prec-to-cos
mflex-me3400(config-pmap-c)# exit
mflex-me3400(config-if)#service-policy input setcos
do let me know how it goes..i still havent had a chance to get my hands on this small beast :-).
HTH-Cheers,
Swaroop
Zsolt.Maj Wed, 06/27/2007 - 06:27
The exact policy-map syntax:
default 5
policy-map setcos
class class-default
set precedence precedence table prec-to-cos
Service-policy on QinQ interface:
Switch(config)#int fa0/4
Switch(config-if)#no shut
Switch(config-if)#swi mode dot1q-tunnel
Switch(config-if)#service-policy input setcos
QM: 'match cos' and 'set' from-type 'cos' supported only with Trunk interfaces
wrong encap type specified for the interface
Unfortunately it is not working.
Zsolt
