cisco discovery tool
May 31st, 2007
Hi guys,
any of you knows where i can download documentation regarding how cisco discovery tool works?
Overall Rating: 4 (1 ratings)
guruprasadr Thu, 05/31/2007 - 00:16
HI, [Pls rate if helps]
CDP is a media and protocol independent protocol that runs on all Cisco-manufactured equipment including routers, bridges, access and communication servers, and switches. - Documentation Section.
Else for more Infn:
PLS Rate if Helps
Best Regards,
Guru Prasad R
Amit Singh Thu, 05/31/2007 - 01:43
You will not able to find the information about CDT as it is not a free public tool available on CCO. It is used by Cisco SE's only and not even by partners. You will not get any documentation on CCO.
If you are a partner, You can open a case at partner central and request for documentation:
Let me know if you have any specific query and I can help.
HTH,please rate if it does.
-amit singh
