Vlan Issue - CE 500 Switch
Magesh G.
Hi, The problem here is im not able to access 2 out of 5 vlans from my CE 500 switch .
All the vlans are configured in cisco 4506 core switch.
Whereas i am able to access all these Vlans in my cisco 2960 switch .
When i check the VTP status in CE 500 and cisco 4506 respectively the following is the output :
CISCO 4506 SWITCH
#show vtp stat
VTP Version : 2
Configuration Revision : 50
Maximum VLANs supported locally : 1005
Number of existing VLANs : 36
VTP Operating Mode : Server
VTP Domain Name : nizwa
VTP Pruning Mode : Enabled
VTP V2 Mode : Enabled
VTP Traps Generation : Enabled
MD5 digest : 0xE6 0xB2 0x66 0x23 0x5B 0x84 0xC3 0x9C
Configuration last modified by 172.25.1.1 at 5-20-07 22:59:23
Local updater ID is 172.25.1.1 on interface Vl1 (lowest numbered VLAN interfa
found)
CE 500 SWITCH
Command was: sh vtp status----------
VTP Version : 2
Configuration Revision : 0
Maximum VLANs supported locally : 36
Number of existing VLANs : 11
VTP Operating Mod : Client
VTP Domain Name :
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0xBA
In Cisco 2960 (all vlan works here), the following is the output ,
bldng31-switch7#show vtp sta
VTP Version : 2
Maximum VLANs supported locally : 255
VTP Operating Mode : Client
can any one tell me what may be the problem ??
please revert.. i am also attaching the configurations !!
Thanks in advance .
10 Replies 10
Anand Narayana
Level 6
Level 6
i couldn't see the domain name :nizwa in ur CE500, so can you configure that & giv the domain name & lemme know the feed back
hi , i just changed the vtp domain name to : nizwa .
After 30 secs the complete network went down .
i could not access the core switch 4506 console .
i had to restart both the switches to restore the network.
kindly revert. it s bit urgent
thanks ...
hey magesh,
assigning the vtp domain name nizwa to the client switch doesn't affect the entire network t go down, can you enable vtp transparent on the switches & send the configuration,so that i can see how it is been configured?
also post the "show vlan".
oj88
Attach a show tech from the CE500.
Did you manually add all the necessary vlans on the CE500? The CE500 AFAIK only supports vtp transparent mode, regardless of what you see in sh vtp status.
yes, All these VLANS were added manually .
Actually the connectivity is something like this,
VLANS configured in Cisco 4506 ,
The fibre backbones from 4506 switch are connected to the CE 500 switch .
The CE 500 is cascaded with the Cisco 2960 switch .
All the vlans work in cisco 2960, but not in CE 500 ?
What may be the issue ?
thanks for all ur responses !!
What firmware version are you running on the CE500?
hi ,
following is the output of
sh version
Cisco IOS Software, CE500 Software (CE500-LANBASEFD-M), Version 12.2(25)SEG, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 02-Jun-06 00:33 by myl
Image text-base: 0x00003000, data-base: 0x0099F03C
ROM: Bootstrap program is CE500 boot loader
BOOTLDR: CE500 Boot Loader (CE500-HBOOT-M) Version 12.2(25r)FY2, RELEASE SOFTWARE (fc1)
Bldg31_core_sw uptime is 1 day, 2 hours, 30 minutes
System restarted at 08:36:09 UTC Wed May 30 2007
System image file is "ucode0:"
cisco WS-CE500G-12TC (PowerPC405) processor (revision B0) with 29696K/3064K bytes of memory.
Processor board ID FOC1105U1RG
Last reset from power-on
1 Virtual Ethernet interface
12 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
90K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1B:0C:F4:70:80
Motherboard assembly number : 73-9836-04
Power supply part number : 341-0097-02
Motherboard serial number : FOC11045GRS
Power supply serial number : AZS110407V0
Model revision number : B0
Motherboard revision number : B0
Model number : WS-CE500G-12TC
System serial number : FOC1105U1RG
Top Assembly Part Number : 800-26637-01
Top Assembly Revision Number : B0
Version ID : V01
CLEI Code Number : COUIACPCAA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 12 WS-CE500G-12TC 12.2(25)SEG CE500-LANBASEFD-M
Configuration register is 0xF
thanks ...
pls revert.
Try upgrading to SEG2. I've had problems before involving 120 CE500s, all with the FY release. I don't know about the SEG release which you now have. But you won't lose anything by going to SEG2, as this release fixed a very major flaw.
If you're interested, here's the link to my original problem: http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40.1dddfcc7
CE 500 SWITCH
VTP Version : 2
VTP Domain Name :
MD5 digest : 0xBA
Well If you look at this output you are missing domain name, either your switch firmware doesnt support VTP or you have misconfigured VTP.
In order for VTP to sync domain names and versions must be identical.
Please recheck these values and try again.
Jaffer
HI ,
Have upgraded the IOS to SEG2 ..
Still same problem .. ??
thanks ...
