05-31-2007 12:21 AM - edited 03-05-2019 04:24 PM
Helllo All,
Is DACL supported on catalyst 3560 48 port PoE standard Image???
Thanks a lot in Advance.
05-31-2007 02:36 AM
Yes, it should work. You have to integrate Cisco ACS with 3560 to do the same. It is supported on Standard Image as moreover it is a feature of ACS to push the acls to 3560.
HTH,please rate if it does.
-amit singh
05-31-2007 06:26 AM
Thanks Mr.Amit
