Cisco Catalyst 6509-NEB-A Switch
Answered Question
May 31st, 2007
Team,
6509-NEB-A Switch ,How many fiber slots comes with this switch and what is the possibity of extending the port?
Correct Answer by Anand Narayana about 10 years 1 month ago
by default the switch doesn't come up any modules added on to like supervisor engine, fiber/coper slot,power supply, any the chassis frame come, the above listed all you will need to purchase at extra cost.
Correct Answer by Amit Singh about 10 years 1 month ago
No fiber slots comes by default. Its a 9-slot chassis and you have to add the fiber modules to it depending your requirement. You need atleast single sup engine in the chassis and then modules depending on your requirement.
Please see the link below of wide variety of modules supported on the chassis.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_relevant_interfaces_and_modules.html
HTH,Please rate if it does.
-amit singh
Overall Rating: 5 (2 ratings)
Correct Answer
Amit Singh Thu, 05/31/2007 - 01:34
  • Cisco Employee,
-amit singh
Correct Answer
Anand Narayana Thu, 05/31/2007 - 02:29
  • Silver, 250 points or more
