05-31-2007 12:45 AM - edited 03-05-2019 04:24 PM
im just new to cisco networking... i have a question and can someone help me on this one. this will be much appreciated. this is my question.
what is dual routing?
tnx in advance....
05-31-2007 12:55 AM
As far as i understand from your query you are asking about forwarding the packets via multiple paths.(which you have mentioned as dual routing)
if thats the case its nothing but having 2 forwarding paths through which you can effectively forward the packets...
The same can happen automatically by virtue of the nature of the routing protocol or else you can manually configure the same based on your requirement..
regds
05-31-2007 01:04 AM
sir, can u give me an exampls of this one?
tnx....
05-31-2007 01:15 AM
Hi ,
dual routing is associated with GPRS ...
Check out below link.
http://www.cisco.com/en/US/products/sw/wirelssw/ps873/products_data_sheet0900aecd80581de2.html
Satish
