pix 515 failure
May 31st, 2007
my pix failed and this is what I have
Use BREAK or ESC to interrupt flash boot.
Use SPACE to begin flash boot immediately.
Reading 1962496 bytes of image from flash.
imgsum_config: sumval(0x3e9f) md5(0x96a6bc99 0xfdcbe539 0x38a4f658 0x28d53468)
imgsum_verify: chksum(0x0 ) md5(0x04a70f1b 0x70b19178 0x3fceeab5 0xd0ae764e)
Checksum verification on compression loader failed.
what is this? I tried to raload image but problem is the same
mwall1 Thu, 05/31/2007 - 07:42
Did you try to re-download the image from the Cisco website (or a newer version)? Maybe the image got corrupted...
What version is that?
dragec Thu, 05/31/2007 - 07:55
6.3.5. I didn't try to redownload it, hmmmm .... will try
dragec Thu, 05/31/2007 - 22:13
I just tried lower version 6.2.2 and problem is the same
mkoncurat Fri, 06/15/2007 - 07:16
I have the same problem with 2 pix 515 units. It all started when I tried to upgrade the license to VPN-Triple DES.
I've tried loading 5.2.9, 6.2.4 and 6.3.5 all with the same error: checksum verification of flash image failed
I've tried erasedisk.bin. This erased as expected, but when I load the OS I get the same problem.
Any help would be greatly appreciated...
dragec Fri, 06/15/2007 - 07:22
well I've sent my unit to be repaired .... so will see .... and let you know
