PIX isakmp identity adddress vs hostname ?
May 31st, 2007
how can I specify the hostname if the default is isakmp identity choosen (hostname) ?
And again, I have different peers configured on my PIX, may I use for some identity address and for other hostname ?
Tks
Ric
ggilbert Thu, 05/31/2007 - 12:40
  • Cisco Employee,
Ric -
You can use the command " isakmp identity address" on the PIX to change from hostname.
To answer your second question, you can either use "isakmp identity address" or " isakmp identity hostname" or the other option is "isakmp identity auto" (if you are running 7.x version of code on the PIX).
Hope this answers your questions.
Cheers
Gilbert
