Vlan Comand query!
May 31st, 2007
Hi Guys, Is there a comand (2950 Switches) to assign multple ports to a vlan in one rather then doing each port individually?
Amit Singh Thu, 05/31/2007 - 02:38
Yes,
Use " interface range fa 0/x - y" command.There is a space between X, "-" and Y where X and Y denotes the module and interface port number.
Do this :
config t
interface ramge fa 0/1 - 10
switcport access vlan 10
You have to check the IOS that you running, if it supports the " range" command.
HTH,Please rate if it does.
-amit singh
