Registration status in CCM 3.3(5)
May 31st, 2007
I have the following problem in a 3 CCM 3.3(5) cluster consisting of 1 publisher/subscriber and 2 subscribers, using 2 different callmanager groups.
Most telephones are registered in Callmanager but if telephones are added to the second callmanager group, they work but have a not registered status in the CCM Administration.
Someboy of you is familiar with this problem and even better is there a solution.
See also the attachment.
TIA
Aad
rob.huffman Thu, 05/31/2007 - 15:15
Hi Aad,
Look for the differences in the 2 CCM Groups. Are all 3 servers (1 Pub and 2 Subs) in both groups? Is there a problem with the DB sync between the first CCM in the non-working group and the Pub?
Let us know.
Rob
aboelhouwers Fri, 06/01/2007 - 01:34
Hi Rob,
Yes in both groups same servers, only the order different. The problem is only related to one specific server. For your information
Grp 1: server 1, server 2, server 3
Grp 2: server 2, server 3, server 1
Grp 3: server 3, server 2, server 1 (problem)
Grp 4: server 3, server 1, server 2 (problem)
the problem is again the registration status, the telephones themselves work fine. In the network config screen on the telephone itself or via the web interface it says: server 3 active, server 2 standby, server1 or server 3 active, server 1 standby, server 2 (depends on grp 3 or 4 chosen).
By the way how do I check the DB sync?
Rgrds
Aad
