VPN Client and 1811
Answered Question
May 31st, 2007
i try to connect to my router Cisco1811 whit Cisco VPN Client 4.8 whit rsa-sig(certificate). On Cisco VPN Client i resive request for username i pass. When i insert them on the 1811 i resive this mesage on console
%CRYPTO-6-VPN_TUNNEL_STATUS: Group: does not exist
My ios config is:
aaa new-model
aaa authentication login VPNUSER local
aaa authorization network VPNUSER local
aaa session-id common
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.10.1
ip dhcp pool sdm-pool
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
lease 0 2
no ip domain lookup
ip domain name yourdomain.com
! crypto pki token default user-pin ******
crypto pki token default removal timeout 30
crypto pki trustpoint TP-self-signed-2095781077
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2095781077
revocation-check none
rsakeypair TP-self-signed-2095781077
crypto pki trustpoint CA_Server
enrollment terminal
serial-number none
fqdn none
ip-address none
password
subject-name O=5100, OU=Customs, CN=Router1
rsakeypair SDM-RSAKey-1180596453000
crypto pki certificate chain TP-self-signed-2095781077
crypto pki certificate chain CA_Server
crypto isakmp policy 10
encr 3des
group 2
crypto isakmp identity dn
crypto isakmp client configuration group guest_group
dns 10.1.1.3
pool vpnpool
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set ESP-3DES-MD5
crypto map vpn_map client authentication list VPNUSER
crypto map vpn_map isakmp authorization list VPNUSER
crypto map vpn_map client configuration address initiate
crypto map vpn_map client configuration address respond
crypto map vpn_map 10 ipsec-isakmp dynamic dynmap
What can i do
Correct Answer by ggilbert about 9 years 11 months ago
What is the OU on the certificate that you have for the client?
is it guest_group or something else?
Gilbert
Overall Rating: 5 (1 ratings)
Correct Answer
ggilbert Thu, 05/31/2007 - 08:53
  • Cisco Employee,
Gilbert
