Stream Alert
May 31st, 2007
Hello
I'm new developper and my customer want to use the ip phone to stream song alert through IP Phone in case of fire or anything else ...
I would like to use RTPMx instruction, but ....
Does any one can help me ?
stephan.steiner Fri, 06/01/2007 - 00:10
but what exactly?
There's a sample java program floating around that allows you to stream a CD quality WAV files to all phones via RTP multicast.. so all that needs to be done is push a corresponding RTPMRx:ip:port to the phones.
malosse Fri, 06/01/2007 - 04:17
dear Stephan
I'm very newbies and since yesterday, i've understand how CCM and ASP scripts work's together to use the RTPMRx function ...
Now, my script work well ;-)
Many thanks Stephan for the time spend to respond to my post ;-)
Best regards
