May 31st, 2007
I need to setup a VPN to an office that does not have a local DNS server. The DNS server is across a MPLS connection. i have the VPN setup on the PIX and you can connect fine but anything that uses UNC paths does not work because a DNS server can not be contacted.
The MPLS network is handled by a 2811 and if you do a trace route to the DNS server it reaches the router and does not go any where after that.
i can post configs if that is helpful
