CCIE R&S hardware lab question: Cisco 3825 (Internetworkexperd digram)
Answered Question
May 31st, 2007
Can anybody please tell me if this router si really needed The only thing that makes this router special is the memory and flash configuration (256 64 1 - WIC-1T). Can you please tell me how crippled will be my lab whithout this or what I can use to emulate this one ?
Thank you
The diagram can be seen here
http://www.internetworkexpert.com/downloads/iewb-rs.sample.lab.pdf
See pag 19.
Cristian
Correct Answer by psprice about 9 years 8 months ago
I've been using a 3640 with 128Mb DRAM/32Mb Flash. It runs all the code you'll need for R&S lab. You WILL run across a 3825 in the real lab so just be aware of the interface numbering.
Overall Rating: 5 (1 ratings)
rgodden Thu, 05/31/2007 - 07:30
i would scroll down down to page , it has gigabit interfaces
cristip Thu, 05/31/2007 - 07:35
I would scroll down one more page to see them connected to Fast Ethernet interfaces :-).
r-godden Thu, 05/31/2007 - 07:54
then i would expect some issues with auto ngotiation which you will need to resolve as part of the lab
Correct Answer
psprice Tue, 06/05/2007 - 11:57
