PPP Multilink Limitations
May 31st, 2007
We are looking ad bonding 8 T1s using a PPP Multilink on either a 2800 or 3800 series router. Is there a limitation on the number of T1s I can bond together and is there a router limitation? For example can a 2821 router only support 6 T1s bonded while a 2851 supports 8-10 and a 3825 support 12-15?
Any input would be appreciated.
THANKS in advance.
Scott
paolo bevilacqua Thu, 05/31/2007 - 17:15
  • Hall of Fame,
    Founding Member
Generally there is a limit of 12 circuits per bundle, even on bigger platforms that the ones you mentioned.
