Disable proactive key caching
May 31st, 2007
I have a setup with a few 1242APs running IOS 12.3(8)JEA1 and have configured PEAP with EAP-GTC and WPA2 using ACS 4.1.
I would like to disable Proactive Key Caching.
Is this possible?
If not, how can I clear/see the PKC cache on an access-point?
thanks,
John
wong34539@yahoo.com Thu, 06/07/2007 - 11:28
If proactive key caching is disabled roaming would be slower. Even then if you want to disable proactive key disable Disable the Wireless Services from Access Point.
Trending Topics - Security & Network
