Configuring a Port in CiscoView is no more possible
May 31st, 2007
Hi there!
After upgrading to LMS 2.6, I'm no longer able to configure a LAN port on a switch with CiscoView. All I get is an Error Message "Error on page", the changes are not acdcepted. I already tried with different IE Versions as well as different JRE versions.
Thanks for any advise!
Joe Clarke Thu, 05/31/2007 - 08:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What device and device package version are you using? Please try the same procedure with Mozilla instead of IE. Hopefully you will be able to reproduce the problem with Mozilla. In that case, putting "javascript:" in the URL field will bring up the JavaScript console, and provide more debugging information about this.
1amoser Thu, 05/31/2007 - 20:59
Actually I'm using CiscoView 6.1.5. Please find the java console output in the attachement. Thanks for any other ideas...
Joe Clarke Thu, 05/31/2007 - 21:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What is the configuration for the port you are trying to configure? I have a feeling the port description is breaking CiscoView.
1amoser Wed, 06/06/2007 - 03:19
The port description is blank and the same problem occurs with any action, taken on a interface e.g. changing duplex mode oder status.
Andy
Joe Clarke Wed, 06/06/2007 - 04:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please provide a screenshot of the port config dialog as well as of the About dialog when viewing the device in question.
